Can't hear other person
From my PC when i call my house landline i can hear the PC end fine but from my PC i can't hear the person on the landline........and yes my speakers are on!
Could anyone help?
Ta
Darren
Have you ensured that the 'softphone' device is linked to your sound card / device? Probably just a box that needs checking :-)
Ok just to update you. When i call othe people it's fine. It's only when they call me.
glloyd
If your using a router, have you opened UDP port 5060 and redirected it to your PC IPaddress? Is your firewalll blocking port 5060?
I hadn't done that but still it's not working after opening the ports.
are there any other ports that need opening?
Another update
I have opened the following ports
UDP 3478 - STUN
UDP 5060 - SIP
UDP 8000 - Xlite RTP
UDP 8001 - Xlite RTP
spoken to Plusnet Technical.
They couldnt help me as i've done evrything they suggested. If this can't be resolved i'll go to a different provider.
I'm an experienced I.T Techy and i can't believe that Plusnet couldnt sort this problem out.
Someone must have had the same problem as me. Just to confirm the problem.
When recieving calls im unable to hear the other person but they are able to hear me.
If i make the call then everything is fine.....
glloyd
When I used Xlite the only port I had open was UDP 6050 and it worked fine. The only thing I can think of is your firewall is blocking something. It may be worth just disabling the firewall to see if that cures the problem.
6050?
are you sure you didnt mean 5060?
oh and yes all firewalls are off.
glloyd
Yes sorry 5060
6050?
