Can't get Hotmail
Richchad
Can't get Hotmail
I only signed up yesterday for Broadband, so thought I would set up my new Plus email account to work with Outlook Express, all okay except when I send email to my Hotmail address from my Plus account either via OE or Webmail it is sent but never arrives? However if I send email from my Freeserve POP3 account or my Lycos HTTP server account it arrives immediately at the Hotmail address.
I can also send email from any of my email address's including Hotmail to my new Plus account without any problems.
Has anyone any ideas?
Can't get Hotmail
Did you try checking your junk mail folder on hotmail?
Just an idea.
Richchad
Can't get Hotmail
Thanks for the reply, checked all hotmail folders, nothing there.
I have raised a ticket for this but it is rather long winded getting replies from 3 different people, the last one ignored all the previous ticket history and told me 'We do not have any identified problems with mail delivery' and to check the set up.
I can't understand why emails sent from my hotmail account arrive at my plus account but not when I reply, it just moves it from the outbox to sent items folder, I do not get any delivery failure message.
Email from my other two accounts, Lycos & Freeserve arrive at Hotmail okay..........strange. Can anyone help?
Can't get Hotmail
Are you sure you have the correct from address setup in your mail client?
Make sure it is in the format user@username.plus.com and not user@username.plus.net or anything else.
Richchad
Can't get Hotmail
Thanks for reply,
I am not sure where you mean to check that I have the correct from address setup im my mail client .
If I send email direct from Hotmail or via OE it arrives okay at my Plus Web mail or via OE, but if I try to return the mail, it is sent but does not arrive at Hotmail either in OE or at the Hotmail website.
Not sure what to try next.............
Can't get Hotmail
OK - So just to clarify, the patter is as followns
PlusNet using OE to PlusNet using OE - OK
Hotmail to PlusNet using OE - OK
PlusNet using OE to Hotmail - Not OK.
If that is correct, then it is still possible the from address is wrong.
In OE, goto Tools -> Accounts.
Under the Mail tab, select your PlusNet account (not Hotmail) and goto properties.
Check that the from address (not the reply-to) read .plus.com on the end, and not.plus.net.
If this is correct, can you please post the full value. If you so wish, post via a private message if your rather it was kept secure.
Can't get Hotmail
As per the reply, it would appear that the correct values are in use.
As you noted, your not very competant at IT, however, you did post everything I needed, and more. So it's not all doom Smiley
Nothing springs to mind right off, and I have no way to testing this myself right off.
Richchad
Can't get Hotmail
Just checked my hotmail account to see what filters were set and guess what I had it set to 'exclusive' which only allows emails already on my contacts list!
Egg & Face spring to mind, what can I say but thanks to you all for your efforts.
