Can i use a site made with WebEasy?
Hi, Can anyone tell me if i can upload a site that i have already built using the Web Easy program? It is only a basic drag and drop program that builds the finished site for you in Dynamic HTML but does not allow inputing any HTML.
If i cannot use it can i use the backgrounds,filters,Gifs etc, that i have made for it? Thanks for any advice. sy9apse.
1 REPLY
I don't actually know that package but as long as it creates standard HTML files I see no reason why it should not work on your www (homepages) webspace.
Why not just try FTPing the files to your www webspace and see what happens.
