Bullet Proof Software BPS Spyware Remover
Alecto
Does anyone know anything meaningful about this pse?
On the grounds that you can never have too much of this type of thing, I've installed it and run it several times, but apart from Adaware SE picking it out as a threat, it always identifies over 2,000 threatening registry entries (which neither adaware nor spybot does), and tells me to delete a list which goes:
Spyware Cleaner
Surveil
Nugache A
sidesearch
Spyaxe.
While I'm some of sure these if I'd got them would be nasty, I find it unlikely that I'd get them time and again, and can see no signs of anything taking over the computer.
My current view is just to uninstall the thing - would that be reasonable?
This product is very dodgy see
http://www.safer-networking.org/en/compatibility/bps.html
http://spywarewarrior.com/rogue_anti-spyware.htm
There is a lot of bad comments out there about this product which is stolen spybot
the best thing to do is put it in the bin
Alecto
Thanks.
I'll stick with what I've got then.
