Browser That keeps Increase/decrease Text settings?
joecool
Hi........Use 'Firefox' & the increase/decrease option, but have to do this each time on use .......Are there any 'Browsers that remember certain viewing settings? beside IE..........
Thx
csogilvie
Not sure if this extension does what you want or not...
joecool
Hi thx.........not sure if it would remember settings on return...........
But thx again
Try opera
joecool
Will do .........thx
joecool
Hi java or non................looks a big one Smiley
Do you have Java already installed on your machine? if not then the Java version might be better.
Are you on a dial-up connection?
joecool
No adsl...........thx again
If your on ADSL why are you worring about a 12MB or so download, it's nothing.
