Blocked Port address ?
Im having problems accessing my webhosts port i.e example.com:2082 - does plus.net block this port ? i've have tried accessing after disabling my firewall etc still doesnt work as it was working a day ago Cry
i've asked my host and they say its from my side.. but i cant figure it out :? ....does anyone know how i can check what ports are blocked on norton firewall 03? and how to change them ?
thanks
ash Tongue
Check the norton logs, it should tell you if access was blocked.
i've checked the logs already, but it didnt show port 2082
ash
If you want to PM me the address, I can test if it is operational here.
So far, tests I have made seem to operate correctly.
When did the issue start?
painswck
I have no problem with port 2082. In fact it is the port normally used by cPanel, as used by most web hosts.
Roland
