Bandwidth usage
Bandwidth usage
Does anyone know how much bandwith the calls use ?
Also what is the monthly bandwidth limit for Broadband Plus ?
LiamM
Bandwidth usage
There are no monthly bandwidth limits for BB+, so you need not worry.
Bandwidth usage
Hi if i rember rightly a post made by a member of comms said that voip would use 80meg per hour of use..
thxs
MrToast
Bandwidth usage
Your 'milage' will vary depending on the data rate.
16kbps and 64kbps are common rates for voice channels (depending on the compression used). However, add about 40kbps of overhead to each of these to give the traffic down the wire. Since there are 3600 seconds in an hour this works out at 25 or 47 MBytes per hour for the above example in each direction.
Depending on your subscription package you may pay for both upload and download.
