Bandwidth Usage
Bandwidth Usage
Just wondering if there is anyway of trackin my bandwidth usage from my website at all??
I forgot to activate web stats so was wondering how many people had downloaded a movie i put on there Smiley
[Moderator's note (by Chris P.): Topic moved to a more suitable forum]
Bandwidth Usage
Webstats is the only way to see access to your webspace, so if it was not enabled there is no way to find out the info you are after.
Bandwidth Usage
Well, if you had gone over your daily bandwidth limit PlusNet would have probably had a word with you by now. Smiley
Thomas
Bandwidth Usage
Got an email asking me to stop using so much bandwidth. Only chekced my mailbox today, found there was 2 notices. So i connected to my webspce to remove the file to find the whole website had gone :shock:
Who do i talk to to get it back?? Or do i have to build it again??
Also, to the plusnet boffins - Sorry for using so much
Tom
Bandwidth Usage
Don't you have the website stored on your PC as a backup?
There is another topic which you may want to read, refering to bandwidth usage and why there is a limit. Website transfer limits
As for your website, I would raise a ticket and see what PN have to say on the matter.
Bandwidth Usage
Don't worry, the site will still be there. Just raise a ticket saying you'll take the necessary measures to reduce your bandwidth...
