BT Speed Tester
BT Speed Tester
Hi All
I wish to run a BT Speed Test, but it will not except my phone number which only has 5 digits after the area code it seems to want 11 digits in total whereas I can only supply 10........ is there a way around this does anyone know?
BT Speed Tester
The number is only needed if you want to report the problem to BT. So just put any old number in to run the test. If you are planning to report it to BT as part of the fault report process then just add a 0 to the end then state in any ticket what you did.
BT Speed Tester
Thanks Peter
Your help is greatly appreciated
IanJ
