Avatar
Brian_E
Avatar
I've created a gif image to use as my avatar, but having (I think) uploaded it to my Web space, nothing except an image placement appears by my name. As I'm new to this I'd appreciate some guidance. By the way, I used CoreFTPLite to upload the file, if that is of any help. It shows the file I uploaded as being in a directory called htdocs
Avatar
The htdocs directory is the root of your webspace.
This means, any file there, is the equivilant of being in http://www.valencia.plus.com/
When placing the URL in your forum profile, you have included the htdocs portion.
The URL you should infact be using it http://www.valencia.plus.com/Sunset01.gif
Brian_E
Avatar
Oh, it's so easy when you know all the finer details. As you can see, it now works. Great!
Avatar
Is it summer already? Cheesy
Thomas
Brian_E
Avatar
In my dreams it is. Wink
Avatar
I have moved this topic from the Feedback section to here as it is a question that was not aimed directly at customer support and is not feedback as such.
