Avast ! & Plusnet ! ?
until I started reading this forum I had never heard of Nod32 or Avast. They do now seem to get much attention in the computer magazines. So all the iknformation we can get on here is very valuable and I am pleased to see it
joecool
Hi using Avast AV Version 4.6 home edtion at the moment which seems excellent............I haven't activated the email protection as yet because I wasn't sure if needed due to 'plusnet's' own email virus scanner & I also use 'Mailwasher Pro'
I thought it might cause a problem ?
Is this so? Do I need to use the Avast email protection ?
Appreciate any help
Thx
The more protection you have the better so turn it on and see what happens. The PlusNet spam and anti-virus scanners are not perfect just like the majority of other spam/AV software.
joecool
OK ! I'll give it a go cheers !!
Download Spamfighter, it's free and does a good job of getting rid of spam Cheesy
joecool
I'll take a look ...thx
Heloman
Re: Avast ! & Plusnet ! ?
Appreciate any help
Thx
I use Avast! which is excellent, as well as Plusnets AV protection. No problem, they complement each other.
Mailwasher is useful for spam protection, and also works fine in tandem with PN's .
joecool
Thx everything is working well together...........Smiley
Avast! is by far the best anti-virus program I have ever used. It out performs Norton, McAfee, Nod, Trend Micro, AVG etc in my humble opinion.
I'm using Avast! e-mailing scanning and it has always done the job well. I switched off Plusnet's e-mail scanning, but I'm going to enable it again. Two layers of protection are indeed better than one! Cheesy
Bold Statement lol NOD32 has the track record of never missing a virus in the wild, I'm not sure avast can claim the same.
Wink
but then we are talking self opinion here :-)
Sakky
I use Avast and the mail protection with no problems at all Cheesy ... but then my pc is protected like Forts Knox Cool
Wink
Yep, I know about how good Nod 32's in-the-wild protection is, I'm just not that keen on the interface and have had problems trying to delete viruses with it in the past. I may re-install it sometime in the future. I'm continually downloading trial versions of anti-virus programs from download.com to evaluate. The only program which caused many problems with errors, blue screens etc was Panda Titanium. Good virus detection, but too buggy and unstable.
I'm installed a 30 day evaluation version of Norman anti-virus yesterday, but have discovered just how expensive it is to buy, so I'll probably be back on Avast! very soon! Wink
house10,
The interface to any program is important, and I think it's where a lot of companies fall down.
I used to use Kaspersky, but the original interface to that was poor, but it was so good at what it did, I kept using it.
NOD32, I've found pretty easy to use and get around, I guess some of the options are not that obvious, but once it's setup it works well.
If your happy with Avast, then it's probably best to stick with that.
