Asterisk SIP Registration
Walneyite
Anybody know of a way round the SIP Response "We don't accept private IP Contacts" Huh
sip settings
I had the same problem I was just about to tear my hair out when I found if I un-ticked the box which says something about recieving calls from a domain it seemed to work. I must say it took me SIX days to get up and running Cheesy
Walneyite
I added the following two lines into SIP.conf manually and it seem to stop the problem
externip=80.229.x.x
localnet=192.168.1.0/255.255.255.0
where x is the number allocated by plusnet. Also I ensured the router I have was passing incoming port 5060 to the internal IP address of the server. Since then no issues...
I've also registered it with SIPGate and FWD so I can get a local incoming number and access to most worldwide 0800 numbers
