Anyone got a Linksys WAG354G to work with Plustalk?
dgp
I am using a Linksys WAG354G Home Gateway and cannot get X-Lite to connect. I have disabled the firewall, used the DMZ and tried port forwarding. Nothing seems to work. I had no problems with my old Netgear 834. The X-Lite log is:
© 2005 CounterPath Solutions Inc. All rights reserved.
X-Lite release 1105x build stamp 21407
Established SIP protocol listen on: 192.168.1.12:5060
Discovered Port Restricted Cone NAT Firewall
SIP: 192.168.1.12:5060
RTP: 192.168.1.12:8000
NAT: 80.229.11.181
NAT: 80.229.11.181
PROXY#0: 84.92.0.75:5060
PROXY#0: 84.92.5.189:5060
PROXY#0: 84.92.5.190:5060
PROXY#0: 84.92.0.76:5060
SEND TIME: 1335908
SEND >> 84.92.0.76:5060
REGISTER sip:pearcefamily.plus.com SIP/2.0
Via: SIP/2.0/UDP 80.229.11.181:5060;rport;branch=z9hG4bK4F6CECDFC671468AABBB5ADA3369D341
From: David Pearce <sip:201502@pearcefamily.plus.com>;tag=2718736615
To: David Pearce <sip:201502@pearcefamily.plus.com>
Contact: "David Pearce" <sip:201502@80.229.11.181:5060>
Call-ID: 59C2B39CC6B745D5A22635983E11AB1E@pearcefamily.plus.com
CSeq: 42318 REGISTER
Expires: 1800
Max-Forwards: 70
User-Agent: X-Lite release 1105x
Content-Length: 0
RECEIVE TIME: 1335976
RECEIVE << 84.92.0.76:5060
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 80.229.11.181:5060;rport=5060;branch=z9hG4bK4F6CECDFC671468AABBB5ADA3369D341
Server: Plusnet-SIP Router (0.7.2 (i386/linux))
Content-Length: 0
Warning: 392 84.92.0.76:5060 "Noisy feedback tells: pid=7374 req_src_ip=80.229.11.181 req_src_port=5060 in_uri=sip:pearcefamily.plus.com out_uri=sip:pearcefamily.plus.com via_cnt==1"
I have seen other people have had similar problems in the past, but has anyone had it sorted out. Or is the Linskys (like some other products) just not compatible with Plustalk. It works perfectly OK with Voipfone, so it is something related to Plustalk. I'm hoping that once I can get X-Lite to connect I can get my PAP 2 working again on Plustalk.
I have also used Plustalk instead of my SIP ID and that makes no difference.
Thanks in advance
David
