Anybody Help ?
Anybody Help ?
Hi there
Each time I enter the discussion forum and click on any item i am getting a window displayd saying
"THis page contains secure and nonsecure items. Do you want to display the nonsecure items/ Yes/No/More Info"
How the hell do I stop this window continually popping up please?
Thanks in anticipation
Paul
Anybody Help ?
Hi
I get round that problem by making sure I read the forums fisrt thing before doing anything that requires going to the secure site for example "connection settings" etc Because I found that if for example I visited "Connection setting" which is a secure server,and then read the forums,they would be still coming from the secure server...... hence the pop-ups.
Thats how I solved the problem,but it may not work for you.But hope it helps
Ian & Linda Jordan
Anybody Help ?
What is happening is that if you visit a "Secure" part of the portal say Account Details then you will see the "http" change to "https" in the address bar above.
This unfortunately sticks with you once you leave the secure area and is the cause of the warnings you get.
Two cures. First just edit the "s" from the address bar to make it "http" again. Or always come direct to the portal without visiting the secure areas.
Oh I've also moved this thread to the everything Internet section as it is not anything "Hardware" related
Anybody Help ?
Thanks for your help guys. I can work around it now.
Paul
