AntiVirus
Golferpete
AntiVirus
Hi to all
I would like some advise as I'm no Pc geek :?
I have AVG antivirus installed on pc, and someone recomended a new
antivirus called Avast 4, what I would like to no is if I downloaded this new
antivirus program would they conflict with each other, or should I leave well
alone, would be gratefull for any help in this matter
Cheers
Peter.
Alecto
AntiVirus
Leave well alone. AVG is a good one and if it's not broken, then don't fix it.
If you do wish to try Avast, which is also supposed to be good, though I've not used it, uninstall AVG first and run something like CrapCleaner to clean out the debris first.
It's not a good idea to run two together. They could conflict.
Golferpete
Antivirus
Hi gpattison
thanks for advise I will take it,and thanks for beening so prompt with it
Peter.
AntiVirus
I have used Avast and AVG, I like both, but thought that Avast was a better antivirus.
As advised don't use two together. However, I do have A2 , spybot, adaware, shredder and Ewido etc. as "standalones" for a spring clean.
AntiVirus
2 BEST free antivirus on the market today, it even beats some commercial AV software/suites Smiley
AntiVirus
I`m a computer engineer and well about the two free antivirus progs if I were to use a percentage of virus found by these two programs against a comercial program then these are not far of the results I have observed
ok comercial first
Kapersky 98%
Norton 95%
F-protect 98%
nod 32 99%
Mcafee 95%
Trend Pc-cillin 99%
Avg 78%
Avast 78%
F-protect is a fairly inexpensive Antivirus solution and in my opinion meets the minimum recommendations
Alecto
AntiVirus
I'd be interested to see the details of those tests gabe.
Can you post a link to them?
AntiVirus
Me too.
They buck the trend of some that I usually refer to.
Thats the first survey where I have seen Norton out perform AVG.
Interesting reading.
Alecto
AntiVirus
Perhaps the viruses got so fed up trying to get through the Norton bloatware they gave up and went away. :lol:
AntiVirus
Iv'e been using Trend PC-cillin for years, simple to use includes AV, firewall, spyware, anti spam, WiFi detection, auto updates, touch wood, never had a virus infection yet.
Only drawback is its not the cheapest, but then you get what you pay for.
AntiVirus
:lol: :lol: Geoff
