Animated (moribund) Gifs
:?: Help please. I've recently tried to amend my existing web site with some help from my grand daughter and we're both puzzled to find that although the animated gifs work ok in the Browser preview (we're using Dreamwaver) in IE6 they aren't working when we upload them to our domain.
Ive just had a look at www.bracklaman.plus.com and there are working animations there? (using IE 6)
If they don't work goto Tools > Internet Options > Advanced.
Scroll down to the multimedia section and ensure "Play Animations" is ticked.
Chris
Is my avatar (on the left) animated for you?
If not, it should be.
:?: :?: Thanks for the tips. I have checked my IE6 settings and the play images checks are ticked.
I'm using Zone Alarm pro is this a problem?
Can't see why it should be but try it disabled and see what happens :?:
Zone Alarm won't cause the problems you mention.
Have you tried a different broswer such as Opera and see if you get the same problem.
Chris
