Alternative to #include?
Hi all,
I want to have a standard navigation bar running down the left-hand side of the website I am developing, and I don't want to have to include this bar on every page.
At work (where we run IIS) I use '.asp' pages and '#include' statements to include the navigation bar.
As PlusNet doesn't support ASP at the moment, what are my alternatives? I have just a basic webspace at the moment (no CGI or FrontPage Extensions). Do I need to enable one of these?
Thanks in advance
Daniel
You can use SSI (Server Side Includes), which work in the same way to the #include statement.
These come in the format
<!--#include virtual="/path/to/file" -->
So if you wanted to include the file http://www.username.plus.com/includes/file.htm
Then you sould use
<!--#include virtual="/includes/file.htm" -->
lowry
Remember that these files need to be saved as .shtml files instead of .html/.html to work as the webserver needs to know that there is included content so that it can get it before it serves the page.
matt Wink
Thanks for the advice.
lowry,
Silly question time Shockedops: - Which file needs to be saved as 'shtml' - the included file (the navigation bar) or the other pages (the content)?
Thanks again
Daniel
Sorry. Yes, the content pages, ie, the ones that include the "<!--#include" line.
Alternatly, you can create a file named ".htaccess" and place it in your htdocs directory, with the following in.
AddType text/html .html
AddHandler server-parsed .html
Your FTP software may make this file vanish, because files starting with a "." (period) are hidden by default.
Look for a settign to display hidden files, or if it asks for the command name for listing files, set it to "ls -la".
