Altering existing web page
Help please at dummy level.
I had a web page designed and uploaded to a .co.uk address through Plus.Net.
I need to remove something from it. Can anyone tell me how to remove it please
Im moving this to a more relevent forum.
You will need to save the document to your PC first, this can be done via Internet Exlplorer or via an FTP package.
Once it's saved to your hard disk you will need a website design program, something like MS Publisher or MSWord can do this for you although they might create more problems than they fix. If you are looking to make a lot of changes you could consider something like Dreamweaver or Frontpage.
Once done you need an FTP package to reupload it.
Chris
If its straight html then its just like using word. If it has php, java or javascript in it then it is a diffrent story.
If you dont know javascript then changing it may stop the site working.
