Alter amount of rings?
glloyd
At the moment when anyone is calling you, you only get four rings before the caller is diverted to voicemail AND they are given your SIP number. That is to short a time to answer unless you happen to be sitting at the computer. Can the amount of rings be extended to something more sensible and your SIP number not be given to external callers?
Does Xlite support other ring tones?
For X-lite:
Click on the menu button (above button 3)
Advanced system settings
call settings
Voicemail settings
Then change the send to voicemail after rings to whatever number you like.
Can't find anywhere to change the ringtone or stop SIP ID being given to caller.
glloyd
Thanks Peter
