Agobot.22.BN
Agobot.22.BN
I seem to be infected with this problem - any idea how to remove it.
Agobot.22.BN
http://www.trendmicro.com/vinfo/virusencyclo/default5.asp?VName=WORM_AGOBOT.BN
Have you tried scanning with ad-aware and spybot search and destroy. Does your ant-virus scanner not detect it and remove it? If you don't have an anti-virus scanner or it is not removing it try another one list in General: Essential Security software. There are also loads on on-line scanners you can run.
Agobot.22.BN
Have tried to clean with anti virus programs but has come up as uncleanable because it is on the opreating system of the hard disc
Agobot.22.BN
Are you running Win XP OS ?
If so, before running your antivirus software, turn off System Restore
Start - Control Panel - System- System Restore
It is likely that this is holding the virus and if so it will reinfect your system unless dumped from the restore files.
Hope that helps.
Mark
Agobot.22.BN
Thanks Mark
Still can,t get rid of this worm.
I run Windows XP Prof.
This worm is on the System and I think this is why it cannot be cleaned.
It is sitting on
C:\WINDOWS\SYSTEM32\EXPLORED.EXE
C:\WINDOWS\SYSTEM32\CONFIG\SYSTEM.LOG
Will I have to uninstall XP and if so how?
Or is the another way to get rid of this problem.
Thanks for anyones help
Don
Agobot.22.BN
You could try the removal tool for this worm available from Norton Here
