Adding a cname - not working
I'm not sure if i have done this correct or not.
Left field: irc ..... [also tried irc.*domain*.co.uk]
Right field: ip to resolve to
irc.*domain*.co.uk will not dns to the ip i added.
Hope someone can help, cheers.
Moderators note by Chris: This is not CGI related. Please use the right forum.
You should be using an A record not a Cname to point to an IP address. Check out the tutorial in the Tutorials and FAQs forum.
Whats the domain name you are having a problem with?
Chris
Have you read this tutorial which refers to setting up domain name records?
If you wish to have irc.domain.co.uk resolve to an IP you should use an A record, not a CNAME.
It should look like that, but change "www" to "irc" and change the IP to that which you want the subdomain to resolve to.
Thanks. How long will it take before it will work?
I beleive 12 to 24 hours on a PlusNet connection and then upto 24 hours more for the rest of the world.
It will all depend how old the cache is on your machine.
csogilvie
24-48 hours until it works its way around the Internet
