Accessing citibank
Accessing citibank
I am unable to access citibank url. although search engins find site, when I click on nothing happens.
I have no probles with other sites.
any ideas?
Sad
Accessing citibank
URL?
Cloudmaster
Accessing citibank
http://www.citibank.com/us/ was the 1st in a google search & is working fine for me
LiamM
Accessing citibank
No problems getting there. Tisn't the fastest site I've been to. But it loads without problems.
ctibank
Any url containing citibank, such as
www.citibank.com.us
ww.citibank.co.uk
displays unknown zone
and returns to 192.193.217.120
or 192.193.117.21
Cry Cry
Cloudmaster
Accessing citibank
www.citibank.com & www.citibank.co.uk are working fine for me
Accessing citibank
Yep, works fine for me.
Fixes: 19
Re: ctibank
www.citibank.com.us
ww.citibank.co.uk
returns to 192.193.217.120 or 192.193.117.21
Assuming that etwall47's OP does not have typo errors, then the URLS (as above) are malformed. They should read http://www.citibank.com/us and http://www.citibank.co.uk ( "." inplace of "/" and a missing "w").
IP addresses in the range 192.193.0.0 - 192.193.255.255 all belong to Citicorp Global Information Network (New York) - this could imply that they had problems when you tried to connect or that their network coughed with the malformed URLs.
Hope you're sorted by now, regards,
Kevin
Accessing citibank
no still the same problem, unknown zone, even with correct urls.
Cry Cry Cry
Accessing citibank
Have you powered off all equipment: PCs routers / modems etc and tried again?
Have you tried without any software firewalls running?
Have you tried after disabling any anti-virus software which may be running in the background?
Accessing citibank
Most likley is spyware/virus or something has changed the host file
