Accessing a wap page
I've uploaded a wml site into a subfloder called "wap" in htdocs. When I tell my phone to go to "http://www.mysite.plus.com/wap" it doesn't find it.
So, I try to be more specific, and access the above plus "/index.wml" but it can't find that either.
Am I missing some fundamental aspect of wml, or summat?
What actual error do you get on the phone?
When serving WAP pages, the server must send the correct mime type in the headers. Depending on the error, I will see if any further info is needed on it.
I'm afraid my phone is one of the less expressive ones.
I put the "wap" folder in the cgi server, pointed my phone at http://cgi.toonlist.plus.com/wap" and got "not found"
So I added the "/index.wml" to the end of the above, and got "not found"
So I transfered the wapsite over to the html server, pointed my phone to "www.toonlist.plus.com/wap" ad still received "not found"
Just out of curiosity, I tried to access my main site, at "http://cgi.toonlist.plus.com" and got a brand new message of "incorrect data type." Which is true, so yaaay @ that.
Is it me not setting up my wml correctly? I've used a wap emulator to view the site on my PC, and all runs fine.
I can't see anything else wrong with it here.
I could only sugest that it is a problem with the phone itself.
It possibly sounds like an issues I have experianced with the HOST http header. If this is, a fix is due to be incorporated into the CGI platform when it is rebuilt.
if you on O2 or T-mobile i doubt you could view the page plus.com seems to have trouble with these netoworks
csogilvie
I don't see why there would be an issue with those two networks on the PlusNet servers, personally. I would be more inclined to think it was the network thats at fault.
