Access problem
Access problem
Hi, need some help with a frustrating problem. Out of nowhere, when I click on sites saved as bookmarks, a pop up box says 'Alert blah blah could not be found. PLease check address and try again.' I haven't changed any settings, and the sites I can no longer visit won't even open when I enter them manually - damn thing just says they can't be found. I can't access half my favourites, and vital study sites. Other sites, bookmarked or not, present no problem. Any help? I use Zonoealarm and Firefox, but the same problem occurs when I use Internet Explorer
1 REPLY
Access problem
I would do a scan for spyware, sounds like spyware is affecting internet explorer
If you don't have a spyware scanner I recommend trying Microsofts free antispyware scanner - Windows Defender
