AVG
AVG
I did a scan today and avg found something in my temp files and said it maybe infected with Exploit.WMF I have moved this file to the vault and deleted all my temp files.....done another scan and it does not pick anything up.
Should I still be worried?? many thanks
AVG
http://www.microsoft.com/technet/security/bulletin/MS06-001.mspx
If you are fully up to date with the windows security updates then it is not a problem. If you are not then you need to update your system via windows update ASAP.
AVG
Ahhhh excellent many thanks
