ASP files
ASP files
Does the webspace with FrontPage Extensions enabled support other ASP files ? For example, jasswiki, a simple ASP based wiki engine.
Thanks,
James
ASP files
No.
The PlusNet Frontpage extentions are run on a linux platform, which doesn't nativly support ASP.
ASP files
Ah! Thanks for the prompt reply.
James
