ADSL Connection
ADSL Connection
My ADSL connection is made via a Binatone 500 modem with two lights. On occasions when I have booted up the power comes on solid green and the line light flashes. In this situation I cannot go online. The problem can occur at any time of day or night and generally resolves itself after a while, or if I re-boot. Has anyone else experienced this? I suspect that it may be an exchange problem but without involving BT it is difficult to check.
ADSL Connection
Check your socket(s)
I had the same problem, a little while ago. Instead of contacting Plusnet, I disconnected my modem from the socket in bedroom, and moved it to another room, works fine. When I replaced to original socket, the same problem arose, erratic connection.
I have got a rewiring job to do.
Harry.G
ADSL Connection
Ihave one of the old modems dynamode never really had and problems with this at all.
