webmail
ian22grant
webmail
why is my webmail not showing messages since yesterday at 12.05?
4 REPLIES 4
Fixes: 388
Re: webmail
Bit of a difficult question to answer, @ian22grant . Could it be that you have exceeded the 1GB limit, although you should have had warnings once the usage reached 75%.
ian22grant
Re: webmail
thank you so very much....I should have known this but....!
Fixes: 251
Re: webmail
@jab1
*.plusnet.com accounts do not stop receiving emails when the 1GB FUP is exceeded, however the legacy brands do not receive new emails when their (250MB) storage allocation is exceeded.
@ian22grant
Which email brand are you using?
Are you sure that there are more recent emails?
Fixes: 388
Re: webmail
Thanks for that info, @Townman . I must check before making comments 😉, but as I don't/never have used ebmail, some of its foibles are unclear to me.
