webmail calender not working
- webmail calender not working
28-06-2012 8:26 PM
stuck
Re: webmail calender not working
28-06-2012 9:35 PM
I tried every which way, but no, I can add events, they just seem to be totally invisible afterwards!
29-06-2012 9:58 PM
HOWEVER - I can't make one from new now (using XPSP3-FF11) - and I can't edit that entry either. The Edit popup appears, I edit it, I press the Save button, the Save button changes to red - and it hangs. The Cancel button works though and I've found I can drag that entry to another date, or even drag one edge to make it a two day event
29-06-2012 10:07 PM
30-06-2012 12:43 PM
Failed in FF 13.0.1.
Customer and Forum Moderator. Windows 10 Firefox 84.0.2 (64-bit)
03-07-2012 3:58 PM
06-07-2012 11:31 AM
06-07-2012 11:39 AM
06-07-2012 2:06 PM
09-07-2012 9:31 PM
09-07-2012 9:54 PM
11-07-2012 11:35 AM
Quote from: drj Just tried again - still not working. I've cleared the cache and deleted all the PlusNet cookies - still no joy. But then I don't and won't be using it so non-critical.
Just created a test event using your account for tomorrow without any problems. I'm using Firefox 13 too.
13-07-2012 11:09 PM
13-07-2012 11:58 PM
17-07-2012 5:52 PM
Problem is all my machines are XPSP3 so I can't try an alternative platform.
On my desktop I've tried FF13, Google 20 and IE8 - none work the calendar; however Chrome is MUCH quicker - but possibly because it refuses to run the site in secure mode. Neither Chrome nor IE8 "trusts" Plusnet...
Don't worry about the fact none of my machines will run the calendar - because I'm never going to use it - but if I can't presumably others might be affected in a similar manner?
