webmail. Basic or advanced.
- Re: webmail. Basic or advanced.
07-01-2012 2:53 PM
Why are there 2 options with web mail, Basic or Advanced ?
What is the advantage of using basic when advanced seems to offer more ? Am I missing something here ?
We are born into history and history is born into us.
Message 1 of 9
(1,922 Views)
8 REPLIES 8
07-01-2012 2:55 PM
Yes you are - Advanced is the Roundcube Trial
Message 2 of 9
(949 Views)
07-01-2012 3:16 PM
Roundcube Trial ?
Tell me more or a link to further info about it.
Message 3 of 9
(949 Views)
07-01-2012 3:21 PM
Message 4 of 9
(949 Views)
07-01-2012 4:16 PM
Thanks for that, cannot understand how I missed that lot !
Just out of interest did Plusnet send an e-mail to all users about this ?
Message 5 of 9
(949 Views)
07-01-2012 5:32 PM
I have no idea but I doubt it
Message 6 of 9
(949 Views)
07-01-2012 5:43 PM
Support for the Roundcube Beta Webmail trial is provided only through the Trial Forum so only registered forum users can access that. It was publicised in this Roundcube Launch blog as well as the forums which I think in total is appropriate to its status.
David
Message 7 of 9
(949 Views)
07-01-2012 5:46 PM
I was advised about the RoundCube trial shortly after joining Plusnet around six months ago owing to problems I had using SquirrelMail, However the problems then at RoundCube were even worse, so I switched back. However after the recent upgrade RoundCube works virtually perfectly. It was then put on general release - and although I don't think an email was issued, there was discussion on this forum.
Message 8 of 9
(949 Views)
07-01-2012 5:49 PM
As from the 1st of December 2011 it was open to all logged in users
Quote from: spraxyt Support for the Roundcube Beta Webmail trial is provided only through the Trial Forum so only registered forum users can access that. It was publicised in this Roundcube Launch blog as well as the forums which I think in total is appropriate to its status.
Message 9 of 9
(949 Views)
