unable to send emails from USA
- Re: unable to send emails from USA
23-08-2019 5:27 PM
in USA and get a server time out message when trying to send emails, able to receive OK. Have checked settings,
Finding it really frustrating to navigate the site and raise a ticket, hence posting this message. All suggestions gratefully received.
23-08-2019 5:54 PM
23-08-2019 6:26 PM
thanks, I'm using Outlook for Mac 2011 so I get a different set of menus that do not include a way of switching on STMP authentication unless I'm missing something obvious,
23-08-2019 9:09 PM
Hi @outinthesticks,
There should be an option on your client to set the SMTP server authentication details manually, which should be the username and password for your account. I am sorry that I can't direct you to the exact place on your client where you can change these settings as they are all set out differently.
