unable to sed emails from abroad
Fixes: 393
Re: unable to sed emails from abroad
@outinthesticks use http://www.whatsmyip.org/ that will give your your public IP
SammyM
Fixes: 96
Hello @outinthesticks,
The link that @MisterW has provided should tell you your IP address when you click on the link. Can you try that and let us know how you get on.
 Sammy M - Sheffield Team
outinthesticks
thanks - its giving me [Removed] as the IP address
Moderator's note by Mike (Mav): Personal information (IP address) removed from a public forum (to an area that staff can see).
Fixes: 1,600
Can you try reporting this to Cloudmark again using the same link but changing the IP address to the one you’re having issues with?
outinthesticks
thanks have done so and got message to say that the IP address might be related to spam - see attached screenshot. I've gone ahead and submitted it anyway.
Fixes: 393
@Gandalf from that screenshot, Cloudmark seem to be assuming that the IP is being used to send mail directly, in which case it might be reasonable to have an appropriate rDNS setting. In this case though, the Cloudmark reputation is ONLY being used to allow/prevent smtp authentication with the PN smtp server. Doesn't seem reasonable in that case to expect rDNS and I'm sure @outinthesticks has no control of the rDNS for a dynamic IP from his ISP.  Maybe time to get Bob involved if the latest reset isn't accepted...
outinthesticks
I am now able to send emails without any problem so I assume that Cloudmark have done a reset, in which case it seems to have worked. Very grateful to everyone who has helped with this. Thank you.
Fixes: 393
That's good news.Smiley
I'm off to Portugal in a couple of weeks so I think I'll bookmark this thread in case I get allocated a problem IP out there
