trouble gett kindle fire to send email
apcarroll
i' m trying to get my mother's kindle to send email, receiving works fine.
i' ve tried both relay and smtp.plus.net servers on ports 25 & 587. seems to set up ok but then doesn't send anything, timing out.
tried with sign- in turned on and off.
any ideas?
cheers,john
4 REPLIES 4
Fixes: 383
Re: trouble gett kindle fire to send email
The outgoing server is relay.plus.net, ports 25 or 587 will both work. You should not need any authentication if you are using a wireless connection on a PlusNet account. You will need authentication if you're using any other wireless connection.
The authentication should not use SSL.
Hope that helps
apcarroll
mister W many thanks for the info, although it matches what i' ve been doing.
i may install another email app rather than using the native kindle one and see if that works.
cheers, John
Fixes: 383
I've no experience with the Kindle ( Fire I assume? ) but I had no problem setting up the normal mail client on my Nexus 7.
The most likely issue is that you have some authentication selected for outgoing server and have not got the username/password correct. The defaults that the mail client tries to insert aren't correct.
You either need your main plusnet username and password ( the one you use to login to the members portal ) or username+mailboxname and mailbox password ( as used to loin to webmail ).
Hope that helps
mseries
Quote from: apcarroll
cheers, John
That would be worth doing. I am reading your thread because I wasn't able to send mail with my Android phone using the preinstalled app. I installed a new email app and it works as expected.
