thunderbird and vpn
- thunderbird and vpn
thunderbird and vpn
13-05-2017 7:47 PM
I've installed a VPN on my windows box. Now when I attempt to send or reply to mail in thunderbird I get a popup message
"<mail address> recipient rejected relay denied". It works fine if I disable the VPN.
I've looked at various "howtos" but all have walkthroughs with menus which do not quite match what I see.
Message 1 of 2
(788 Views)
1 REPLY 1
Re: thunderbird and vpn
13-05-2017 8:30 PM
assume you're using PN email?
if so you need to add authentication as with a VPN you're no longer on the PN network.
Message 2 of 2
(775 Views)
