spam box and aliases
- spam box and aliases
02-11-2011 10:20 AM
I look at my e-mails with IMAP and only just noticed that I dont have a spam box on my alias redirect Odds address.
been into manage my accounts and cant find how to create one, just to see if any go there.
How do I look?
How do I look?
Message 1 of 6
(1,407 Views)
5 REPLIES 5
Re: spam box and aliases
02-11-2011 11:17 AM
As far as I'm aware the mail system automatically creates a Spam folder for each mailbox if it needs one. So the absence of such a folder implies that mailbox has not received any spam. Two of my mailboxes don't have Spam folders. Aliases wouldn't have a separate Spam folder, only the target mailbox.
David
Message 2 of 6
(488 Views)
02-11-2011 3:21 PM
The creation of the 'Spam' folder is conditional and based on the following:
If the latter hasn't happened then you won't see a Spam folder in your subscription list.
As it happens though, you do have a Spam folder and a message has been sat in there since Saturday. You'll probably need to tell your mail client to subscribe to the folder though.
- You have the option enabled to move spam messages to the Spam folder under the 'Spam' tab in Manage My Mail (you have).
- An incoming message has been identified by the system as spam and an attempt made to move it to the Spam folder.
Message 3 of 6
(488 Views)
02-11-2011 9:17 PM
eventually did it Bob, that e-mail is in my blocked addresses list, but the last two are still slipping through
software_innovations4@stateez.com
software_innovations5@deeanin.com
bounce@email-cp.co.uk
software_innovations5@constong.com
software_innovations5@purpath.com
connorsmum@aim.com
software_innovations5@zanytop.com
marketing@freelancer-direct.co.uk
From: "Freelancer" <marketing@freelancer-direct.co.uk>
connorsmum@aim.com
Message 4 of 6
(488 Views)
02-11-2011 11:31 PM
Hi pierre, are you still getting messages from @zanytop.com or is it just the last entry on your blocked list that doesn't work? Have you tried terminating the last entry with a carriage-return to see if that makes a difference?
All the best
Chris
edit: sorry, this might belong on your other thread....
All the best
Chris
Message 5 of 6
(488 Views)
03-11-2011 7:06 AM
you are correct I had forgotten about the other tread when I put that in, got more from Zanytop yesterday
Message 6 of 6
(488 Views)
