smtp settings on Android phone have stopped working
- smtp settings on Android phone have stopped workin...
19-02-2015 10:39 PM
For some reason relay.plus.net reports authentication failed on my Galaxy. Was working a couple of days ago.
Details; relay.plus.net
Security Type None
Port 587
Require Sign In ticked
Username Account username+email
Password same as the +email account
Any suggestions please?
Security Type None
Port 587
Message 1 of 4
(863 Views)
3 REPLIES 3
Re: smtp settings on Android phone have stopped working
19-02-2015 10:54 PM
It's just started working again! Weird, I didn't change any settings.
Message 2 of 4
(434 Views)
19-02-2015 11:17 PM
The settings information looked OK to me. I was about to suggest checking if authentication was working using telnet from a PC. See guide.
However no need since it's working again.
David
Message 3 of 4
(434 Views)
21-02-2015 6:28 PM
More often than not, any SMTP connectivity issue is reported as an authentication failure issue.
Logically (for whatever real cause) the net result is that authentication could not be verified...
Message 4 of 4
(434 Views)
