setting up Outlook 2019 for first time
Fixes: 778
Re: setting up Outlook 2019 for first time
Thanks for posting what fixed the problem @bladerunnerplus
I've made a note of this thread to refer back to in future I need to.
Let us know if there's anything else you'd need help with.
crimsom
I use an earlier version of Microsoft Office's Outlook and Automatic setup failed saying "An encrypted connection to your mail server is not available." However an encrypted Manual setup is possible. Here's what I used for PlusNet Email's incoming (IMAP or POP3) and outgoing (SMTP) server settings:-
IMAP Settings
POP3 Settings
SMTP Settings
Server:
imap.plus.net
mail.plus.net
relay.plus.net
Port:
993
995
465
SSL/TLS:
OK
OK
OK
These server settings require an encrypted (SSL/TLS) connection
The SMTP server uses port 25 by default, or port 587, and 465 for encrypted SSL/TLS connections.
The POP3 server uses port 110 by default, and 995 for encrypted SSL/TLS connections.
The IMAP server uses port 143 by default, and 993 for encrypted SSL/TLS connections.
Kind regards.
Fixes: 33
