problems with folders in outlook
tetchytim
since last week when plus net generally was causing problems accessing the internet i have had problems accessing emails through outlook
so raised a question via messenger was asked if i had changed password recently which i hadn't and was advised to remove the account from outlook and adding it back syncing it back up in the process, problem is how or where do i do the syncing as all my folders i had created prior with some important emails in are longer showing up in outlook only in web mail and ever thing i have done since dosnt seem to work
6 REPLIES 6
Fixes: 251
Re: problems with folders in outlook
Probably a hiccup in Outlook.  Sometimes for no explicable reason, you need to specify the IMAP root folder in the server sync settings - if it is needed, it should be inbox
Alternatively, if (for whatever reason) you set up the new account in Outlook as POP3 you will only see the inbox folder - nothing else.
tetchytim
using outlook 2010 i think and not outlook for windows
is the reference about IMAP relates to ? (outlook for widows)as just tired to set up my email account and with this email they are asking for imap.plus.net and this doesn't seem to work
Fixes: 480
Do you think or do you know? There are many versions of Outlook and they are all different.
Sounds like you have been very poorly advised if you have deleted your accounts.
If you are setting up an account from scratch you need to know whether you are using POP3 or IMAP. If all your messages are on web mail then it must be IMAP.
It is years since I used the obsolete Outlook 2010 but from memory:
Do not try to use the automatic settings in Outlook, switch to manual mode.
In Outlook 2010 account settings the required server settings are:
Account Type IMAP
The rest is here: https://www.plus.net/help/email-guides/how-to-set-up-plusnet-email/
Fixes: 251
IIRC encryption will not work with Outlook 2010. It’s time to upgrade!!
tetchytim
been use to this for a long time what upgrade would you suggest and what would be best way to get emails of web mail to it
Fixes: 251
Depends what you need. MS Office (365) subscription is circa £7pcm that gives you everything. Win11 has a mail app which will do but has limitations.
Thunderbird is used by many and is free.
There are others - use google to see what’s available.
