problem sending email
edwardaustin
Interested
I switched to btinternet about 4 years ago. I have continued to use my plus.net address and use btinternet as my outgoing server. This has always worked fine until a couple of days ago. When I try to send a message I get the following error message  - can't connect to the account "outgoing server for btinternet"
I have not changed any settings or password. I have checked the outgoing settings and they look correct but I am unable to send any emails.
Is anyone able to suggest how I go about rectifying this problem.
Thanks in advance
2 REPLIES 2
spraxyt
Fixes: 75
Re: problem sending email
I assume you also have a btinternet address. If you try sending using that address does it work?
David
edwardaustin
Interested
Thanks for your reply. I've spent ages on this to discover that the btinternet address had been disabled. I have now re-enabled it and should be able to put all the settings back.
Thanks again
