password recovery
gleneagles
Aspiring Legend
Fixes: 17
password recovery
Is there any way to recover a password for access to one of my plusnet mail addresses ?
We are born into history and history is born into us.
5 REPLIES 5
Fixes: 395
Re: password recovery
'recover' , No , but you can 'change' any mailbox password from Manage My Mail in the Member centre
gleneagles
Aspiring Legend
Fixes: 17
Thanks but the problem is it's the default mailbox, there is a rename option but no edit or delete option.
I have checked under the other tabs in manage my mail but cannot see any sort of option that would allow me access to that mailbox.
Mav
Fixes: 515
Isn't the default mailbox password the same as what is used to access the Member Centre?
Forum Moderator and Customer
gleneagles
Aspiring Legend
Fixes: 17
@Mav
Yes, you are correct, thanks for that.
Smiley
Mav
Fixes: 515
@gleneagles
Did you mean to set the Fix to yourselfWink
