outlook 2000 professional email problem.
- Re: outlook 2000 professional email problem.
05-09-2012 3:28 PM
Yesterday Zak looked at my email setup with a problem which is solved now but it seems now my gmail a/c isnt working since the email problem was looked at by zak remotely yesterday.Im sure its got nothing to do with zaks work yesterday.I have a gmaila/c.a.plusnet a/c and an hotmail a/c,all of which worked ok yesterday but now they still all work apart from the gmail a/c.Its says on my outlook that,Could not fetch the headers to the inbox of imap.gmail.com.Can anyone help please.regards ray.
Message 1 of 6
(1,399 Views)
5 REPLIES 5
05-09-2012 3:39 PM
Hi Ray,
It sounds that from my perspective it should be as simple as removing the gmail account from outlook and then readding it.
Can you give that a go to see if it fixes the problem?
Message 2 of 6
(493 Views)
05-09-2012 3:56 PM
I will Jameseh,thanks.
Message 3 of 6
(493 Views)
05-09-2012 4:22 PM
Deleted gmail a/c and put it back into my outlook 2000 pro but still giving me the same error message.I have noticed theres only an inbox now,before i had all sorts of folders.
Message 4 of 6
(493 Views)
05-09-2012 4:26 PM
The other folders will appear once it is able to get the headers (which it can't fetch currently).
Are you setting it up like in this guide?
http://www.emailaddressmanager.com/tips/outlook-gmail.html
(You'll need to set it up as a imap account and not pop3).
Message 5 of 6
(493 Views)
05-09-2012 6:20 PM
Jameseh thanks for that,just got it sorted and it seems to be working fine now.regards and up the spurs.
Message 6 of 6
(493 Views)
