opening/reading messages
bob27
When I go into my Inbox (Outlook Express) messages are displayed int the Preview pane "automatically"
Is there any way I can avoid this so that  a message is only displayed, say, when I click on the message.
It seems to me that automatically displaying a message is inviting security lapses.
8 REPLIES 8
Santiago
Re: opening/reading messages
In Outlook Express menu bar at the top, if you click on View then in the dropdown list click on Layout.
This opens a new window. The lower half of the window has the set up details for the Preview Pane. Untick the option to Show Preview Pane and click on OK. This will give you what you want. If you want to reinstate the preview pane in the future simply go back and tick the option
pierre_pierre
another one on the same line, can Thunderbird just show the header and not download the mail - I get a regular trusted 2M mail but would like to delay the download until require, this must slso be a security problem downloading unknown mail  - I am using IMAP
bob27
Thanks a lot ODDBALL.  It works just fine. Smiley
Santiago
You're welcome
@pierre-pierre
IIRC in Thunderbird IMAP Inbox you can can turn the message pane on and off from the View option.
pierre_pierre
yes thats F8, but it still downloads the file, not good if its a dodgy file
bobpullen
Fixes: 316
Just checked my Thunderbird install and emails aren't downloaded for me if I've the preview pane closed. I'm using IMAP as well, although I've disabled the option that synchronises your local machine with what's on the server. Perhaps that's what you need to do Pierre?
Help > Migration Assistant (assuming you're using Thunderbird 3):
pierre_pierre
mine slightly different (more up to date Roll_eyes )
Disk space
This new version of Thunderbird comes with a new and better search functionality.  To experience this new search you'll need to synchronize your email messages.
Synchronize Required: 85.3 MB
You'll see faster message loading and better search results.
Do not Synchronize
This will mean slower message loading and incomplete search results.
Per Account Synchronization
Customize your synchronization needs per account and folder.
the last one was interesting, it lets SWMBO sychronise,  on my one with the large daily not to, listed all my mail boxes - I have 7
bobpullen
Fixes: 316
Quote from: pierre_pierre
So it is! Looks like I'm still running 3.0.4 on the work lappy.
