opening/reading messages
- opening/reading messages
15-08-2010 5:50 PM
Is there any way I can avoid this so that a message is only displayed, say, when I click on the message.
It seems to me that automatically displaying a message is inviting security lapses.
Re: opening/reading messages
15-08-2010 6:41 PM
This opens a new window. The lower half of the window has the set up details for the Preview Pane. Untick the option to Show Preview Pane and click on OK. This will give you what you want. If you want to reinstate the preview pane in the future simply go back and tick the option
15-08-2010 7:00 PM
15-08-2010 7:40 PM
15-08-2010 10:51 PM
@pierre-pierre
IIRC in Thunderbird IMAP Inbox you can can turn the message pane on and off from the View option.
15-08-2010 10:53 PM
16-08-2010 11:12 AM
Help > Migration Assistant (assuming you're using Thunderbird 3):
16-08-2010 11:25 AM
Quote Disk space
This new version of Thunderbird comes with a new and better search functionality. To experience this new search you'll need to synchronize your email messages.
Synchronize Required: 85.3 MB
You'll see faster message loading and better search results.
Do not Synchronize
This will mean slower message loading and incomplete search results.
Per Account Synchronization
Customize your synchronization needs per account and folder.
the last one was interesting, it lets SWMBO sychronise, on my one with the large daily not to, listed all my mail boxes - I have 7
16-08-2010 11:55 AM
Quote from: pierre_pierre mine slightly different (more up to date )
So it is! Looks like I'm still running 3.0.4 on the work lappy.
