maximum number of recipients
- maximum number of recipients
05-09-2015 1:00 AM
Does plusnet block emails with multiple recipients in order to reduce spamming and if so what is the maximum recipients allowed?
Message 1 of 2
(890 Views)
1 REPLY 1
Re: maximum number of recipients
05-09-2015 1:08 PM
Are you referring to receiving emails or to sending them.?
For sending a few months ago a Plusnet staff member posted...
David
Quote from: Bob I believe the limits for sending over a Plusnet connection are 1000 recipients per hour (or 250 recipients per email). Off network, it's a lot less (300 per hour and 250 per email, I think). I'm not 100% sure about Webmail but I assume it to be similar.
Quote from: Bob Our Webmail platform has stricter policies applied to customers using it from outside of the UK and one of these policies is to limit the number of recipients per email to a maximum of 10.
David
David
Message 2 of 2
(607 Views)
