iPhone - can't delete messages with attachments
- iPhone - can't delete messages with attachments
01-07-2015 10:59 PM
I have the same Plusnet IMAP email address on both devices and can delete any message on the iPad but when I try to delete messages on the iPhone I can delete text only messages but when I try to delete a message with an attachment I get a " this message could not be moved to Trash” message box.
I've checked the mail settings on both devices and they are identical.
I also have a gmail IMAP address and can delete messages with attachments on both devices so don’t understand why it’s only the Plusnet messages with attachments that I can’t delete on the iPhone ?
Re: iPhone - can't delete messages with attachments
01-07-2015 11:04 PM
Try setting the IMAP Path Prefix to INBOX in advanced settings for the email account on the iPhone and see if that fixes it.
02-07-2015 12:04 PM
03-07-2015 10:23 AM
03-07-2015 1:28 PM
My iPad which is also on IOS 8 does not have anything in that field and deletes the messages without any problems.
dick:quote
03-07-2015 2:26 PM
03-07-2015 3:02 PM
I'll give it a try when I get home
dick:quote
03-07-2015 6:06 PM
...that said sometimes on my PC the Outlook client fails to complete the move from the inbox to the trash folder...
...Just remembered something - are you sure on the device which is failing that under the advanced settings, you have "mapped" the deleted items folder to the IMAP junk folder? As I was about to click post I recalled a similar experience with someone who had not mapped deleted items to the IMAP folders...
HTH.
03-07-2015 8:58 PM
I've deleted the mailbox on the iPhone and re-created it but the problem is still there and i've also tried a restart on the iPhone but this didn't fix the problem
I've re-checked the advanced mail settings on the iPhone and they are identical to those on the iPad so why I can delete the messages with attachments on the iPad and not the iPhone I have no idea and why the problem is only with messages that have an attachment as I can delete text only messages on the iPhone
This appears to be limited to my Plusnet email account as the gmail account I have on both devices does not have this problem.
06-07-2015 12:56 PM
You could probably test this by logging into the mailbox using Webmail, right-clicking the Inbox and then left-clicking 'Compact'. You should then revisit the iPhone and see if there's been any change in behaviour/the emails you can see.
Failing that, can you confirm that you've tried the guidance in the third post down here.
