how do i add website link to my emails
- Re: how do i add website link to my emails
07-03-2014 3:47 PM
Message 1 of 5
(998 Views)
4 REPLIES 4
07-03-2014 3:50 PM
using webmail or an email client and if a client which one
also whichever you are using have you changed from text only format to html
Message 2 of 5
(592 Views)
16-03-2014 8:30 PM
Thank you for your reply i am using webmail and plain text.
Message 3 of 5
(592 Views)
16-03-2014 10:02 PM
in which case you need to change to html otherwise it will only be text and not a link
Message 4 of 5
(592 Views)
16-03-2014 10:29 PM
Doesn't need to be HTML - you should enter the URL in the form of
<http://www.whateverdomain.com/>and it should be a clickable link when received by the majority of mail clients.
Message 5 of 5
(592 Views)
