help setting up email sending on Mac at University
- help setting up email sending on Mac at University
22-09-2011 9:32 PM
Can anyone walk me though this please
Re: help setting up email sending on Mac at University
22-09-2011 11:01 PM
22-09-2011 11:07 PM
23-09-2011 9:00 AM
23-09-2011 9:09 AM
I'm also a mac user.
23-09-2011 10:08 AM
Is there a difference
To be is to do - Kant
do be do be do - Sinatra
23-09-2011 10:12 AM
23-09-2011 10:17 AM
23-09-2011 10:22 AM
23-09-2011 10:23 AM
23-09-2011 10:29 AM
http://www.plus.net/support/email/setup/index.shtml
23-09-2011 10:29 AM
Phil
23-09-2011 10:57 AM
Quote from: pjmarsh You can send from a non-Plusnet connection using authenticated SMTP if the network you are connected to allows it.
In the Email Setup Guides page of the Plusnet Support Pages, there is a walkthrough for Mac Mail for Snow Leopard which works for Lion too (I've checked). IF the network you are connected to allows it, you can send email using authenticated SMTP - you just need to do something slightly different at steps 7 and 8 of the walkthrough:
7. Tick "Use Authentication".
Type in the username and password for your mailbox (which may be different from your Plusnet account details - i.e. the mailbox username may be in the format of PlusnetUsername+MailboxUsername).
8. Set "Authentication" to "Password".
This thread discusses the fact that this is possible, and also that Plusnet don't offer secured SMTP.
And some networks/ISPs/mobile phone data providers don't allow traffic on the unsecured SMTP port so this won't work for them either.
23-09-2011 11:10 AM
We have tried the Use Authentication and it isn't working so it sounds like the University (Kingston Upon Thames) is blocking SMPT.
23-09-2011 1:31 PM
Given that the uni is blocking SMTP in some way, an alternative that I'd recommend is Gmail. You can use it as is, with a new Gmail address etc.
And if you also want to continue to send and receive email from your Plusnet mailbox, you can set up Gmail to collect email from your POP3 mailbox, and send email through the Plusnet SMTP mail server (making sure you set the port to 25, and authentication to password only, and no encryption/security). To most people, it will then seem like your email address etc hasn't changed - you'd just be using Gmail as your email program.
To do this, once you've set up your Gmail account and are logged in, click on the gear icon in the top right hand corner, then "Mail settings".
Then in the "Accounts and Import" tab, under "Send mail as", click the button "Send mail from another address" and follow the prompts to enter the details and set it up to send mail using an SMTP server.
Once you've done this, in the same "Accounts and Import" tab, under "Check mail using POP3", click the button "Add POP3 email account" and follow the prompts to enter the details.
HTH.
