gmail messages not being sent
geetee2
Hi everybody.
I have just switched from BT to Plusnet, and set up a Gmail account. My BT email is now basic but available for 60 days.
So I am trying to send emails from Gmail but they come back as address does not exist. This is not correct, because I can still send to this address from BT using my BT email address.
Everything else is fine with Gmail, so can anyone help please, hopefully in fairly simple language that a nonteccy can understand.
12 REPLIES 12
Fixes: 388
Re: gmail messages not being sent
Where/who are you trying to send to from Gmail?
geetee2
HI. Another Gmail address
Fixes: 388
@geetee2 That suggests to me that either your Gmail account is not set up correctly (although you do say 'Everything else is fine with Gmail') or you are trying to send to a wrongly addressed recipient.
I do not use Gmail, but those are the only two scenarios I can think of. Does this happen if you try any address as the recipient?
geetee2
Strangely, I can reply to that address successfully, but still cannot send although the addresses are identical. I have tried from contacts and putting in manually.
I am not sure what you mean by ANY address
Fixes: 388
That unfortunately does not make any sense to me - if you can reply to the address, but cannot send an original message, it suggests to me that something is wrong in the formatting of the address in your original message(s).
I mean - can you send to any other contacts via Gmail successfully?
@geetee2
FYI, I also transferred from BT to Plusnet - in my case last June. I was also told that I would only have "basic" email, and then only for 60 days.
I was told that "basic" meant that I would only be able to access my BT email from a web browser - not an email client, for only a "limited time", and my family's "sub" accounts would cease to work.
The reality, in my case at least is that nothing seems to have changed:
I still access my BT email account through Thunderbird email client, send and receive email, (just tested to confirm), and my family's email accounts still work.
I think the only real requirement is to keep the BT accounts active by logging in to each account from a web browser regularly, say once a month?
geetee2
Yes, I agree it does not make sense. I have just tried another Gmail address and a BT address and both seem to have been sent.
Can you suggest what might be wrong in the formatting, because the address looks identical whether reply, contacts or manual.
Also, I sent to the other Gmail via contacts and that seems to have worked, as I said
Fixes: 388
@Anonymous A bit like my old Tiscali mail, which worked until they (TakTalk) closed the Tiscali mail platform down late last/early this year, although I never used it once I had switched to PN - still got loads of spam via them, though.
geetee2
Thank you for that. I will bear it in mind.
Fixes: 388
I have no idea, but to be honest, it does not make sense to me.
@Townman ?
geetee2
Hi jab1.
I have sorted it now. I deleted the contact and added from another file and it all works. I can only think there was a fault in the address line, but what I do not know.
Thank you very much for your help.
Fixes: 388
Good to see it sorted.
