can't send emails
- Re: can't send emails
can't send emails
30-03-2020 4:45 PM
I suddenly, today, can't send emails from my computer and get a message saying check smtp settings. Does anyone have any ideas why this would have happened? I have tried to ring plus net but they are not answering calls
18-04-2020 5:55 PM
A warm welcome to the forums.
Did you get a resolution to this issue? Sorry that it has not been responded to here - the staff are under a great load - and no other customer has picked this up.
Assuming that passwords are correct, that you have a working internet connection, the most likely cause is that you IP address has been associated with SPAM activity and has therefore been black balled. Such does not mean that YOU are responsible for the spam, rather that some previous user of that dynamic address was.
You can try to 'resolve' this by powering down the router for two hours and then turn it back on. That should ensure that you are allocated a new dynamic IP address, which hopefully will be clean.
If this post helped, please click the Thumbs Up and if it fixed your issue, please click This fixed my problem
