Where does Thunderbird store its data? Solved
- Re: Where does Thunderbird store its data? Solve...
16-05-2010 8:05 PM
I have a Win 7 Media PC that I use Thunderbird as my POP 3 downloader, my Motherboard has done a mischief and has to go away for repair, Got most of my data backed up but not all the Thunderbird.
I have the SATA HD in a cradle on a Win XP, where are the e-mail files? and what are the file extensions?
Ta in expectation
Ta in expectation
Message 1 of 4
(3,726 Views)
3 REPLIES 3
16-05-2010 9:03 PM
I have XP Pro and the Thunderbird mail is here
C:\Documents and Settings\username\Application Data\Thunderbird\Profiles\iwn8n73e.default
Message 2 of 4
(1,157 Views)
16-05-2010 9:22 PM
Except yours will have different letters and numbers in front of ".default". If you are looking to copy the data from a Win 7 HD you will find it here,
C:\Users\[your username]\AppData\Roaming\Thunderbird\iwn8n73e.default
Message 3 of 4
(1,157 Views)
Re: Where does Thunderbird store its data? Solved
16-05-2010 9:54 PM
Thanks Denzil, got the files off the SATA HD, now to put it back and send it off - covered on warranty post free
Message 4 of 4
(1,157 Views)
